Brief Description: Warning/alert indicators and dimmers
Today I installed three lights purchased from Stein in the panel. I had not decided before hand when designing the panel lay out so this was done "willie nille". I finally decided where I think I can live with everything and marked the locations and drilled. I will use the green light to indicate when the fuel bosst is switched on. The red light will illuminate when the oil psi drops to a certain psi and will be coupled with the master switch and hobbs so that it will shine during shut down. I have left that thing on too many times and had a dead battery to greet me on return. The amber light is undecided at the moment but could be used for landing light on or over voltage etc...
I also decided on location and drilled for two dimmer potentiometers I got from Vans. I left enough room for ease of turning and for labels beneath.
I also added some more glass and epoxy miv to the fwd top edge of left skirt
