Brief Description: Swap a two lever for 3 lever throttle quadrant
I had purchased the 3 lever throttle quadrant from Vans because the 2 lever one needed a spacer so that the rear throttle lever rod would line up with the front. But I didnt like the crude spacer I made and thought the 3 lever top faceplate would fit nicer and also have the throttle lever in the correct position. My plan is to just remove the rpm lever for the prop since I wont need it with a constant pitch prop. I will send the other unit back if this fits the way I hope. I can see that the cover that surrounds the throttle plate needs some cutting and a change in a plte nut before it fits. No surprise there!
