Baker's RV-6
RV-6
Systems
4-29-2014
Assisted with Engine Start/Swapped Ignition Leads
Randy Brooks helped with the engine start and swapping the coax connections to the left coil pack.
The coax connections properly plugged in
The in-line fuse holder where the fuse had blown. A 10-amp fuse was reinstalled
The right coil pack runs cylinders #3 and #4
RV-6 Home
5540
544
Control Systems
Cowling
164
199
666
124
570
Flight Training
1225
Inspection
Instrument Panel
142
227
256
Shop Construction
Systems
Weighing
1334
Wiring
126
216
