Brief Description: Control Stick Bolts Tightened and Torqued
The castle nuts (AN310-4) were bolted in place on the control stick bolts and the cotter pins were installed. The manual aileron trim connecting lengths and springs were also attached to the connecting rod bolts on each stick. The bolts attaching both control sticks to the lower connecting rod were bolted in place and torqued. The nuts and washers were marked with torque seal.
The right control stick bolted in place
The lower portion of the right control stick bolted and marked
