Brief Description: Oil Door Clecoed/Trimmed Cowl for Exhaust
The oil door was clecoed in place with the Hartwell latches also clecoed in place. The latches will need spacers at the front end of the latches. Currently washers are used in lieu of doublers.
Tape was applied along the exhaust line of the cowling. This area had not been trimmed earlier. The cutoff wheel in the Dremel was used for cutting off the two inches.
