Brief Description: Sanded Cowling Extensions/Pulled Tape off Cowl
I used 60 grit sandpaper to sand the cowling extensions. The tape was taken off the drilled holes in the cowling. The SuperFil filled all of the holes and the tape gave the SuperFil a nice smooth edge to the covered holes.
Right extension after sanding
Left extension after sanding
The top cowling-the light spots are the drilled holes that have been filled with SuperFil
