Baker's RV-6
Date:  3-15-2011
Number of Hours:  0.10
Brief Description:  Glued Fiberglass Sheets Together for Extensions
The bids of fiberglass were glued together on the plastic sheet. After the six bids were glued together, the plastic was pulled over the top of the bids and the roller was used to squeegee out the excess epoxy. The plastic and bids were then cut out. Epoxy was brushed onto the inside of the cowling.
The bids were glued together and then squeegeed
The roller was used to squeegee any excess out
The bids were cut out of the plastic sheets
