Brief Description: Rec New Control Cable Bracket/Need Replacement
I took photos of the new and the old control cable bracket received from Aerotronics. The new bracket is bent under the panel, instead of the way the old bracket is made. I sent the comparison photos to Jason-Aerotronics and then talked with Jason. He said that he would have another bracket made that will be identical to the old one, with the four holes drilled in it. I ordered a new cable bracket because I am not installing an alternate air cable.
The new bracket from Aerotronics, that will be remade
The original control cable bracket, that will be replaced
