Baker's RV-6
Date:  10-5-2010
Number of Hours:  2.50
Brief Description:  Axle Spacers/Installed Left Brake Mounting Flanges
I made six spacers, three per side, per the plans. I had to install the Cleveland brake mounting flange on the inboard side of the U-403 brake mounting flange on each gear leg. I put the wheels on the gear too soon, but since I had the help that day, I installed the gear legs. Now I had to take the brake mounting flange off again. I got the U-403 off and installed the Cleveland brake mounting flange on the axle, then reinstalled the U-403. I added the bolts. spacers, and the U-810 wheel fairing mount and torqued the bolts. I took the ring off the wheel bearing to see how the bearing is installed.
The spacers
The spacers
The brake mounting flange with the Cleveland mounting flange
The top two rings and the felt that rests on top of the wheel bearing
