I taped and covered the interior in preparation of painting the canopy supports. I primed the supports and then spray-painted them with the Rustoleum paint. I bolted the canopy roll bar in place. I had to replace the called-for bolts in the plans with the next longer size. I used SuperGlue to glue the washers to the nuts, trying to make it easier to get the nuts/washers onto the bolts. It took a while, but Bernie and I finally got them on. They were torqued down. The canopy rails were screwed in place with the nutplate strips. The aft two screws were too short, so I need to get longer AN509-8R10 or -8R12 countersunk screws.
The interior covered so that the side canopy supports could be repainted
