Brief Description: Drilled Pilot Holes for Canopy Assist Handles
I began to drill holes for the handles in the roll bar. I began with a #40 bit and drilled the starter holes on the back side of the roll bar spaced four inches apart. I drilled one hole thru the front for each handle. The right side was not square so I filed one edge of the hole to try to move it over. I started to upsize the holes.
