Brief Description: Drilled Tip-Up Support Bracket to Frame
I positioned the tip-up canopy support bracket on the underside of the frame and marked the position. The inside canopy skirt was modified by cutting off one tab to give the support bracket room. The inside canopy skirt was clecoed to the frame along with the side skirt to ensure clearance for the screw that will be on the support bracket.
The inside skirt modified for the support bracket
The canopy tip-up support bracket positioned on the frame
