Baker's RV-6
Date:  7-8-2010
Number of Hours:  4.00
Brief Description:  Drilled Left Canopy Skirt thru Canopy/Inside Skirt
The left canopy skirt was clecoed in place and the holes were drilled thru the skirt, the canopy, and the inside skirt. I countersunk the middle row of holes and dimpled the bottom row in both canopy skirts. I dimpled the inside skirt holes as well. I drilled the top holes in the outside skirt to #30 siz. I then used the 1/8'' plexiglass bit to drill thru the canopy, starting in the center and working outward. I then used a #30 bit to enlarge the canopy hole by hand and then drilled thru the inside skirt. The top row was drilled thru.
