I clamped the left C-759 inside canopy skirt to the bow and, using a strap duplicator, drilled it to the bow. The left skirt was then clecoed over the inside canopy skirt to the bow and the holes were drilled up to #30. I repeated the process and drilled the right skirt and the C-759 to the right canopy bow. The right bow was also about 1/8'' high at front. I had problems drilling the right inside skirt to the bow. I did not get the skirt low enough and so the skirt stuck up above the outside skirt as much as 1/4'' in the center. I repositioned the inside skirt in a better position and drilled two new holes to pin it in place. I then drilled new #40 holes in the inside skirt with the strap duplicator. Some holes were new and others were drilled on the edge of the old holes. I clecoed the outside skirt on top and then enlarged all of the holes to #30.
Drilling left C-759 inside skirt to bow with strap duplicator
Left inside canopy skirt
Left canopy skirt drilled to bow and inside canopy skirt
