Brief Description: Placed Wedges under the Canopy Roll Bar
Tim Conway also had small wedges made to fit under the forward part of the canopy roll bar. I positioned the wedges under the base of the roll bar and marked the hole location. The hole was drilled to a #12 size. I cleaned up the large wedge on the Scotchbrite wheel and primed it, along with the small wedges.
Wedges that Tim had milled
A wedge after priming and drilled into place under the canopy roll bar
