Brief Description: Spiral-wrapped and Labeled Wires
The wires from the wings going up the fuselage sides were wrapped with spiral wrap. The wires behind the panel were spiral-wrapped to other wire wraps.
The two sets of landing light wires from the left wing had about 12'' of the outer insulation stripped off. The shield was cut off on each set. The pair of orange wires was cut off and had heat shrink applied over the cut ends. The wires were labeled.
Left landing wire power wire and AeroLed green master wire
