The ring terminals were cut off each of the black wires that had been screwed onto the light switches. Each end of wire had heat shrink applied to it.
I labeled the landing light wires. I ran the Wigwag yellow and the blue wires from the left and right wings respectively up along the sidewalks and under the instument sub-panel. The wires were crimped into a connector and then a blue wire was crimped into the other end of the connector. This wire will have a pin added to the other end and put into the P-1-0 connector.
I made labels for the AeroLed light wires. The yellow WigWag wire was labeled.
