Brief Description: AOA Tubing/Fuel Tank Sending Wire
The Dynon EMS-120 was removed from the panel. The AOA blue tube was run up the left side of the fuselage and had the tee fitting attached to it. The tube was reattached to the Dynon D-100 and the clear AOA tube from the tee fitting on the AOA processor.
The wire for the right fuel tank sending unit had a ring terminal crimped onto it. The ring terminal was screwed onto the sending unit screw.
