Brief Description: Pulled Cover off Lightspeed Wires
After Joe Walker pulled off the 15-pin connector from the Lightspeed control box, we noted all of the pins from the two sets of wires and compared them to the drawing I received from Jason-Aerotronics. Jason's drawing shows that a power wire should run from the 7/8 and 14/15 pins to the Electric Ignition circuit breaker. Another wire is to go from the breaker to the battery with a slo-blo 7 1/2 amp fuse.
The pins from the wires into the connector were noted. It looks like pins 7, 8, 14, and 15 are already used with the shielded wire. More investigation is needed.
