The hole for the carb heat cable was enlarged from 3/8" to 7/16" with a Unibit. The cable bracket was installed, replacing the plastic snap bushing. The bracket was hand-tightened and needs to be tightened.
The first few wires were installed in the P-1 CPC. The wires were put in, but will need to be removed. I was in too much of a hurry to speed things along. Shrink wrap needs to be installed and the cap on the CPC as well.
The carb heat cable bracket
The bracket on the cockpit side
The P-1 terminal with the first few wires installed
