Brief Description: Drilled Pilot Hole in Firewall for Wiring
I had marked the distance on the EGT/CHT thermocouple wires that indicated the amount of slack needed for pulling out the Dynon EMS unit for maintenance. I tied off the wires at this point. The wires will be clamped along the bracket on the rib. A pilot hole in the firewall was drilled for the wires going to the engine.
