I added Adel clamps to one corner of each cooling fan for the wiring. I added another Adel clamp for the dimmer wire. I attached two cooling tubes to each cooling fan and laid out the preliminary route for these tubes. I used a Unibit to drill holes in the instrument subpanel for the tubes to go thru.
I found that the screw in the top right corner of the clock on the panel had broken off. I took the clock out and attempted to unscrew the body of the screw out, with no luck. I will probably just glue the head back into the hole and leave it.
I cut off the end of the OAT wire and, per the EAA Homebuilders video, cut and separated the shielded wire.
