Brief Description: Doubler for WigWag Controller/Cooling Fan Wires
I cut out a .063" doubler, about 3 X 5 1/2," for attaching the WigWag controller to the side of a rib in the instrument panel. I drilled out eleven lightening holes in it and riveted nutplates to it, after priming it. I riveted the doubler to the right-hand rib, so that it remains in place.
I received a splitter wire for the two cooling fans from Isaac-Aerotronics, as well as a 9-pin D-sub connector.
