Brief Description: Drilled Center Rib Bracket/Riveted Canopy Rail
I drilled pilot holes in the angle bracket for the center rib. I drilled pilot holes in the C-661 canopy slide block for the bolt holes. I bent the C-762 canopy slide rail over the 45 degree bend of the C-763 canopy slide spacer. The two pieces were clamped together and I drilled the hole for the screw at the leading edge. I marked holes every 1 3/4" across the top of the rail. I drilled the rivet holes in the rail and the spacer and countersunk both sides of the holes.
