Baker's RV-6
Date:  4-23-2014
Number of Hours:  0.50
Brief Description:  Pulled Wire off Starter/Added Jumper
Randy and I talked about a jumper cable that I had found. The bag was marked "Starter Cable." I called Sky-tec, manufacturer of the starter. The tech I talked with directed me to a diagram on their website. This clearly shows the jumper cable. The tech stated that he had heard of many RV builders removing that jumper cable, which should not be done. I had removed it and replaced it with a long wire from the starter relay. The long wire was removed by Randy and he added the jumper cable.
The jumper cable installed on the starter
