Brief Description: Taped/Clamped Brake Lines to Legs/Eng Mount
I taped the brake lines to the gear legs with electrical tape. I am going to run the right brake line along the mount. I put two one-inch MS21919-16 Adel clamps on the mount and tied some safety wire around each clamp. I put an MS21919-5 Adel clamp on the brake line and bolted it to the larger clamp. I attached the crossing exhaust hangers to the hanger clamps and then tightened the clamps around the tubing. Update: 10/25/10-The exhaust hangers attached to the engine mount were moved to the engine sump.
The latest Aircraft Spruce Order: included Mouse Milk and LPS2
The center hangers for the exhaust
The exhaust hangers in place--Changed their position the next day
