Baker's RV-6
Date:  5-6-2014
Number of Hours:  3.50
Brief Description:  Tech Counselor Visit
Dave Ross visited and conducted a Technical Counselor visit. He looked over the engine compartment and made some suggestions for me. He demonstrated the proper method to tie Koroseal, the plastic wire wrap used on the Scat tubing. He suggested that the cabin heat Scat tubes and the heat muff on the exhaust be reversed. The starter cable was also too close to the fuel line, so that was rerouted under the engine mount. The heat muff was reversed. He said to keep moving wires and hoses away from each other, as well as away from the engine mount.
The cabin heat muff after reversing it. The diffuser indicates the outlet
Tanis heater wires with the starter wire below
Starter wire rerouted
