Baker's RV-6
Date:  10-18-2012
Brief Description:  Reinstalled In-Line Fuse Holder/Oil Press Wire
The in-line fuse holder was crimped back onto the Lightspeed ignition power wire. The ground from the power wire was resoldered onto the ground wire.
The Low Oil Pressure light wire was switched to the other post. I discovered that the posts are labeled NO and C. I thought that the wire might go onto the C post so the wire was switched.
The ground soldered onto the ground wire
The in-line fuse holder in place
The Low Oil Pressure wire moved to the C post
