The Low Oil Pressure light wire was labeled and then crimped a Molex connector onto the wire. A ring terminal was crimped onto the other end of the wire and the wire was installed on the Hobbs pressure switch. While I was laying under the panel, I noticed that the Bezel lighting inverter still needed to be reattached onto the subpanel. I got the Allen wrench needed and reattached the inverter to the subpanel behind the Dynon D-100.
The Low Oil Pressure light labeled
The Low Oil Pressure wire attached to the Hobbs pressure switch
The Bezel light inverter is reattached to the subpanel
