Brief Description: Made the Other Two Fittings/Added Tee Fitting
Now that I knew how to properly make fittings, I made the other two fittings after checking the proper length of hose needed for the third hose. This hose will go between the Hobbs beter pressure switch and the tee fitting. The steel tee fitting was screwed onto two of the fittings. The two lines of hose were finger-tightened onto the engine fitting and the oil pressure transducer. the position of the tee fitting was checked for clearance along the firewall.
