Brief Description: Drilled Inlet Hole in Carb Heat Deck
The carb heat inlet position was marked on the deck and the inside of the inlet was also marked in red. This area's outline was drilled with a #30 bit to knock out the center. The inlet was match-drilled to the deck and then nutplates were riveted to the inlet.
