Baker's RV-6
Date:  1-7-2012
Number of Hours:  1.00
Brief Description:  Deck Drilled to Carb Heat Box
#40 pilot holes were drilled in the carb heat box for attaching the deck with sheet metal screws. The deck was positioned on the box and the pilot holes were extended to the deck. The holes on the deck were enlarged for the sheet metal screws. The carb heat inlet was positioned on the deck and its position was marked in place.
The deck drilled to the carb heat box
The deck with the holes enlarged
The inlet positioned on the deck
