Brief Description: Set Air Inlet Hole in Baffle/Ran Starter Wire
I positioned the air inlet hose attach point to the aft right rear baffle and drilled it to the baffle. The two-inch hole needs to be drilled in the baffle.
The P2 cable was run through the firewall hole and screwed to the master relay.
The air inlet hose attach point clecoed to the baffle
