Brief Description: Drilled Hole in Firewall for Fuel Line Fitting
I was reviewing how I could reorient the gascolator when Tim Conway showed up. He brought a few electrical caps to see which would work for covering up the 9/16" hole drilled thru the firewall and the gascolator bracket. The larger bracket was used, but the top edge had to be trimmed off. The primer hole in the bracket was enlarged and a new screw hole was drilled for attaching the gascolator in its new orientation, rotated 90 degrees . We drilled a new hole in the firewall and inserted a bulkhead fitting. A 45 degree fitting was inserted into the gascolator to see how the connecting tube would run.
Visitor-Rick Katai
New hole drilled in firewall next to engine mount with the gascolator in its new position
