Brief Description: Modify the Gascolator and Fuel Line Routing
I exchanged the 90 degree fitting on the gascolator with a 45 degree fitting to see it that would have better clearance from the engine mount. I did give a little more, but after adding the connector, the clearance is almost zero again. I will have to rotate the gascolator 90 degrees and drill a new hole thru the firewall for the fuel line. The hole already drilled will have to be covered or patched.
The 45 degree fitting and the lack of clearance with the mount
The gascolator's current position, which will have to be rotated 90 degrees
