Brief Description: Left Landing Light/Nav-Strobe Light Installed
The left wingtip was removed from the wing. The left landing light was inserted into the wing and screwed into the tilted forward position. The ground wire for the left nav and strobe lights was attached to the bottom inboard screw. The landing light ground wire was screwed to the bottom outboard screw.
I attempted to insert a landing light lens cover into the wing. The lens covers need to be reduced in size so that they can be inserted into the wing openings.
The left landing light is on!
