Brief Description: Nav Wires in Wings/Screwed Rt Wing to Fuselage
I tried to push the nav wires thru the conduit. The wire was hung up in the area where I had used tie wraps as the conduit came thru the two closest ribs to the fuselage. The tie wraps were cut off on each side, but the wire still was getting hung up.
The left wing with the 18 ga wire and the strobe wire
