Baker's RV-6
Date:  11-20-2013
Brief Description:  Trimmed Fuselage Opening for Flap Control Rod
The bolt on the left flap thru the actuator was removed. The top of the opening was filed some more. The bolt was reattached and the movement was checked. The rod still rubbed against the fuselage. The bolt was removed and more filing was done. This was done a few more times. A washer was inserted on each side of the control rod.
Left flap actuator bolted to control rod
