Baker's RV-6
Date:  7-19-2013
Brief Description:  AOA Tubing Attached to Ports
The tubing, blue and green, for the AOA system was run thru the plastic tubing in the left wing. The blue tube was attached to the top port. The green tube was attached to the bottom port.
The AOA tubing, with the blue tubing attached to the top port
The AOA tubing coming thru the wing behind the fuel tank
