Brief Description: Pitot Heat Controller and Wiring
The wiring for the pitot heat controller was run thru the plastic tubing. Holes were drilled in the two aft ribs next to the fuel tank for the pitot and static tubing. Plastic grommets were snapped into the holes.
The nutplate on the access panel side
Pitot heat wiring and grommets in the holes for the tubing
