Baker's RV-6
Date:  3-7-2012
Number of Hours:  0.50
Brief Description:  Drilled Center of Right Spar for Wiring
The center of the right main spar was drilled for the wires that will be run thru the area. A plastic bushing with an ID of 1/2", OD of 5/8" was used to check the cutout. The center of the left spar was also checked and the cutout was enlarged slightly.
The center fuselage was drilled for a second hole, 5/8" diameter. The snap bushings were installed in the center fuselage in both holes. Wires were run thru the bushings.
The cutout in the right spar
The center fuselage with wires run thru
