Brief Description: Right Tank, Rib 1-Check Pushed-Over Rivet
Wanted to look at one rivet at LE of rib 1, right tank, because shop head was pushed over when rivet was worked. Removed Proseal with MEK. Dave & I looked at it and decided that it would be better to leave. Risk of drilling it out is that, because the dimple was bent, the new rivet may be worse than the one it replaced. Tore off numerous strips of painter's tape for next ribs.
