Brief Description: Completed Work on Aileron Control Rod
Drilled Heim bearing to aileron control rod. Poured linseed oil inside aileron control rod. Riveted Heim bearings to aileron control rod using pneumatic squeezer. Installed aileron on brackets. Installed aileron control rod on bellcrank. Hole in rear spar will need to be widened.
