Brief Description: Left Aileron Bellcrank/Top Skin
Drilled hole in bottom skin in bellcrank cover area & rib 9. Deburred remainder of holes on inside of bottom inboard skin. Clecoed bottom inboard skin to ribs & spars. Took off bottom outboard skin. Drew 3/16" & 3/8" lines on inside of top outboard skin. Drilled top outboard skin to main spar & a few holes down the rib lines.
