Brief Description: Aligned Skeleton/Drilled Skin to Ribs/Spar
Drilled & bolted a support to the inboard end jig. Clamped rear spar to this support & confirmed position w/plumb bob. Drilled remainder of main spar holes except for rib/spar holes. Drilled skin to ribs starting w/rib 5, working down & outward. Drilled rib/spar holes. Drilled skin to rear spar.
