Picked up wooden clamps from Dale Wimmer. Measured centerline of holes drilled for forward spar in skins and then located ends of forward spar. Drilled holes thru tips of forward spar and right tip ribs. Finish-drilled all holes on right side w/#30 bit in all ribs and spars. Reinstalled right skin and clamped down. Aligned all ribs and spar and then drilled all holes in right HS thru skin, ribs and spars with 3/32" bit. Visitors-Tim Brannan, Larry Dispenza
