Brief Description: Finished down angles of elevators
I took a little more material off the F-611E spacer and got another degree of down movement of the elevators. The down angle is now at 23°. I then took the elevator and the HS off the fuselage.
Elevator control horns in place
Cut-outs of HS rear spar for the down angle of the elevators
Close-up of left elevator horn and cutouts of HS rear spar and spacer
