Brief Description: Aligned Elevators with Horizontal Stabilizer
I pulled out the one alignment pin in the elevator that I could not get earlier. I used the Dremel and a sanding cylinder to slightly enlarge the trim cable hole in the HS rear spar. I screwed in two rod-end bearings into the left elevator. I measured all four bearing heights to be 13/16'', per the plans. I attached both elevators to the HS and inserted alignment pins. Clamped each outboard end of elevator to the HS. Each elevator is properly aligned with the HS. Placed and clamped the HS and the attached elevators in position on the fuselage.
