Brief Description: Made a Cable-End Fastener for Oil Cooler Cable
Scott Brown made a cable-end fastener for the oil cooler cable. He ground down the end of a castle nut and drilled a hole in an AN3 bolt. The fastener was tightened and we attempted to move the cable. The cable opened with some resistance, but the cable bends when the cooler door is closed. More work is needed on this.
Scott also helped with checking the position of the aileron bellcranks.
