Brief Description: Enlarged Left Control Stick Opening/#1 Comm Coax
The opening for the left control stick was enlarged and both holes were cleaned up and smoothed. The openings now allow a full range of movement by the control sticks.
The coax for the #1 comm antenna was run thru the first seat rib. A rubber grommet was slit and then slid over the wire. The grommet was inserted into the rib and the coax was screwed onto the antenna lead.
